Hydrostat Sticking
/ Hydrostat Sticking #1
chastst
Has anyone else experienced this?
My B7500 has started "sticking", when I lift my foot off the forward or reverse pedal, it does not return to neutral, the tractor just slows to a crawl in whichever direction it was last traveling? Is this a pedal issue or a hydrostatic drive issue?
TIA,
chastst
/ Hydrostat Sticking #2
Chastst,
The obvious questions. Tractor age, how many hours since the last HST oil change? Which oil was used? Are you using Kubota SuperUDT? Have you checked the peddle pivot point for dirt or obstruction? Is it well lubricated? I don't see a location. Is it now very cold in your local? Just some thought,
regards,
Steve
/ Hydrostat Sticking #3
chastst
try a search under something like "HST not returning" or "sticky HST". I know since I've joined, this question has been asked a few times. /forums/images/graemlins/grin.gif
/ Hydrostat Sticking #4
I have had this problem from time to time, and it seems to be worse during cold weather. There is a zerc at the pivot point on the hydrostat pedal that should be greased regularly. I always get my FEL and BH, but usually forget that one zerc. Give that a try and I'm sure it will go away. You have to work the pedal a bit after greasing before it really loosens up again.
Hope this helps,
Greg
/ Hydrostat Sticking #5
Greg, Is this why I can not back up some times? I have been pushing snow for two days, but finally done. I will try it.
/ Hydrostat Sticking #6
DDT,
The syptom I was addressing was a sticky hydro pedal. In other words, if you take your foot off it, it doesn't center in the neutral position. If you can't get it to reverse, that sounds more like on obstruction in the linkage. I have had that happen a couple of times with sticks getting stuck in the linkage. In your case, it might be ice or packed snow? Just guessing.
Greg
/ Hydrostat Sticking #7
As I indicated in my prior post, re: lubrication and/vs obstruction.
regards,
Steve
/ Hydrostat Sticking #8
Greg I think your right. I went out a little today about 2 hours and no problems. My shed is heated so my problem melted away.
/ Hydrostat Sticking #9
That's the kind of repair that I love! /forums/images/graemlins/laugh.gif Mother Nature is a lot cheaper than the shop rate at the Kubota dealer! /forums/images/graemlins/grin.gif
Greg
/ Hydrostat Sticking #10
</font><font color="blue" class="small">( I have had this problem from time to time, and it seems to be worse during cold weather. There is a zerc at the pivot point on the hydrostat pedal that should be greased regularly. I always get my FEL and BH, but usually forget that one zerc. Give that a try and I'm sure it will go away. You have to work the pedal a bit after greasing before it really loosens up again. Hope this helps,
Greg
)</font>
Now where exactly is this zerk? I've crawled under my B7500 and can't see one anywhere on the shafts, bars, linkage, etc., and I'd looked there before since it's a moving joints and seems logical to be one in there somewhere...I can't find it or a hole where one goes.
/ Hydrostat Sticking #11
"Now where exactly is this zerk?"
On my B7510 it is on the end of the shaft that the pedal pivots on.
Look under the floorboard and move the hydro pedal a little and you will see where the shaft is. There should be a zerk fitting on the end of the shaft.
One possibility if you are not seeing a zerk is that it has been broken off by a big limb. In that case you should see the remains of it on the end of the shaft.
BTW, I am assuming the 7500 is the same as the 7510. If it is not ignore this post!
Bill Tolle
/ Hydrostat Sticking #12
Yup, what Bill said...... /forums/images/graemlins/smile.gif That little zerc is a kinda hard to find, but if you look at the pivot point on the pedal shafts, it's right around there. If you need it, I could take a photo later today.
Greg
