Hydrostat pedal dampner
/ Hydrostat pedal dampner #1
blackoak
3 kubotas
What is the part called that pulls your hydrostat pedal back into neutral when you let off of it? I think mine is bad on my B3030. The tractor will move on its own if I get off. My pedal has no compression when moving it forward or in reverse. I can't find a parts diagram to get a part number. Been searching for an hour with no luck
/ Hydrostat pedal dampner #2
Messicks has the parts diagram.
Is this it? Part #130?
/ Hydrostat pedal dampner #3
Any debrie build up?
/ Hydrostat pedal dampner #4
These 2-way dampers wear out and stop working in one direction, then both. They're important because they soften the pressure spike inside the hst when F-R shifts are abrupt.
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2011 Ford F150 (A66408)
2011 Ford F150...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
6ft Kodiak Extra Heavy-Duty Rotary Cutter (A65579)
6ft Kodiak Extra...
Conveyor (A64194)
Conveyor (A64194)
