Hydrostat pedal dampner
/ Hydrostat pedal dampner #1
blackoak
3 kubotas
What is the part called that pulls your hydrostat pedal back into neutral when you let off of it? I think mine is bad on my B3030. The tractor will move on its own if I get off. My pedal has no compression when moving it forward or in reverse. I can't find a parts diagram to get a part number. Been searching for an hour with no luck
/ Hydrostat pedal dampner #2
Messicks has the parts diagram.
Is this it? Part #130?
/ Hydrostat pedal dampner #3
Any debrie build up?
/ Hydrostat pedal dampner #4
These 2-way dampers wear out and stop working in one direction, then both. They're important because they soften the pressure spike inside the hst when F-R shifts are abrupt.
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
HD Running Gear (A66408)
HD Running Gear...
Iranch High-End Tricycle (A64119)
Iranch High-End...
