hydrolic problem cat 320 bl 1997
/ hydrolic problem cat 320 bl 1997 #1
gavin26er
gtown
cat 320 bl
when i push out the dipper stick and pull in the stick all the way it stalls the engine. i tryed everything i can think ive changed the filters, cut them apart also no cutting. two new presure switches on valves. when using dipper switch there is a hissing noise. also if someone knows where to get a shop manual.
gavin
/ hydrolic problem cat 320 bl 1997 #2
gavin
Almost sounds like a relief valve line might have an internal collapse that when goes to supply oil the oil is backing up to pump and causing motor to pull down. Could also be electrical. on one of our 320C's the aux and fuel wire rubbed and when used the aux, the power from the aux increased fuel to motor. Would blow smoke and almost die, you could have the opposite and just losing fuel
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63118)
Magnolia Trailer...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
