hydrolic problem cat 320 bl 1997
/ hydrolic problem cat 320 bl 1997 #1
gavin26er
gtown
cat 320 bl
when i push out the dipper stick and pull in the stick all the way it stalls the engine. i tryed everything i can think ive changed the filters, cut them apart also no cutting. two new presure switches on valves. when using dipper switch there is a hissing noise. also if someone knows where to get a shop manual.
gavin
/ hydrolic problem cat 320 bl 1997 #2
gavin
Almost sounds like a relief valve line might have an internal collapse that when goes to supply oil the oil is backing up to pump and causing motor to pull down. Could also be electrical. on one of our 320C's the aux and fuel wire rubbed and when used the aux, the power from the aux increased fuel to motor. Would blow smoke and almost die, you could have the opposite and just losing fuel
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
(10) Free Standing 24' Cow Panels w/1 Gate (A64119)
(10) Free Standing...
2023 ASV RT-40 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-40...
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A61572)
2016 Kubota SSV75...
UNUSED MOWER KING (A64281)
UNUSED MOWER KING...
