hydrolic noise
/ hydrolic noise #1
brother Dave
Gray Court, S.C.
Farmtrac 535
I have a 2009 Farmtrac 535; changed the hydroic filter, now have noise like air being pumped through system, almost like a loud rattle. Turned steering point to point, lifted 3ph point to point, still makes noise. Any ideas?
/ hydrolic noise #3
A loud rattle in hydraulics is sometimes related to pump cavitation.
/ hydrolic noise
I checked the filter and found nothing out of order; and I tightened the hose connection (didn't need it), have plenty of fluid for the 3ph. Any other suggestions?
/ hydrolic noise #6
Did you remove a pressure hose and place in a bucket to see if the pump was pumping at the pump specified volume as in GPM?
Look for air bubbles in the hyd fluid stream.
If you have a hyd gage, what is the pressure reading?
/ hydrolic noise #7
Where is the filter you changed located?
Pump inlet or suction line
If pump inlet where you able to pre-fill the element before installing or is it horizontal?
If pump inlet, Are you 110% the seal or gasket was not damaged or compromised in any way?
Return line: This should not cause cavitation unless the seal is allowing air to be sucked in from fluid flow and aerating the reservoir.
/ hydrolic noise
I don't have a hydraulic gage, but I have one for water pressure on my pressure washer. Will that work?
/ hydrolic noise
I am going to try another new filter, then another site. You assumed too much with your spelling test! I know how to spell, I do have a college degree and I'll bet you understood what I was trying to convey to you, regardless of how the word (gauge) was spelled. I have been down many roads in my long life and continually run into people who are overly impressed with themselves. Which is more correct? Insullting or insulting?
/ hydrolic noise #11
I don't think JJ was trying to be offensive...he did give you a link to a good site for gauges...and he used the spelling gage FIRST...so I think his question was a legitimate one...wondering which spelling is preferred..
/ hydrolic noise #12
brother Dave,
Chill out dude, it was only a question.
I was trying to find out which is more correct from anybody that knows.
I use gage myself. No offence to you or any one else.
As far as college, I don't have any and I guess that makes you smarter than me.
Use whatever spelling you want.
The two words are interchangeable for the most part.
UNUSED WOLVERINE TDB-11-72W 72" BUCKET (A64281)
UNUSED WOLVERINE...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
Caterpillar CP-563/CS-563 Parts and Service Manuals (A63117)
Caterpillar...
2020 Inifiniti Q 50 Sedan (A61574)
2020 Inifiniti Q...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
2015 CAT 259D Track Loader (A63111)
2015 CAT 259D...
