hydrolic noise
/ hydrolic noise #1
brother Dave
Gray Court, S.C.
Farmtrac 535
I have a 2009 Farmtrac 535; changed the hydroic filter, now have noise like air being pumped through system, almost like a loud rattle. Turned steering point to point, lifted 3ph point to point, still makes noise. Any ideas?
/ hydrolic noise #3
A loud rattle in hydraulics is sometimes related to pump cavitation.
/ hydrolic noise
I checked the filter and found nothing out of order; and I tightened the hose connection (didn't need it), have plenty of fluid for the 3ph. Any other suggestions?
/ hydrolic noise #6
Did you remove a pressure hose and place in a bucket to see if the pump was pumping at the pump specified volume as in GPM?
Look for air bubbles in the hyd fluid stream.
If you have a hyd gage, what is the pressure reading?
/ hydrolic noise #7
Where is the filter you changed located?
Pump inlet or suction line
If pump inlet where you able to pre-fill the element before installing or is it horizontal?
If pump inlet, Are you 110% the seal or gasket was not damaged or compromised in any way?
Return line: This should not cause cavitation unless the seal is allowing air to be sucked in from fluid flow and aerating the reservoir.
/ hydrolic noise
I don't have a hydraulic gage, but I have one for water pressure on my pressure washer. Will that work?
/ hydrolic noise
I am going to try another new filter, then another site. You assumed too much with your spelling test! I know how to spell, I do have a college degree and I'll bet you understood what I was trying to convey to you, regardless of how the word (gauge) was spelled. I have been down many roads in my long life and continually run into people who are overly impressed with themselves. Which is more correct? Insullting or insulting?
/ hydrolic noise #11
I don't think JJ was trying to be offensive...he did give you a link to a good site for gauges...and he used the spelling gage FIRST...so I think his question was a legitimate one...wondering which spelling is preferred..
/ hydrolic noise #12
brother Dave,
Chill out dude, it was only a question.
I was trying to find out which is more correct from anybody that knows.
I use gage myself. No offence to you or any one else.
As far as college, I don't have any and I guess that makes you smarter than me.
Use whatever spelling you want.
The two words are interchangeable for the most part.
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
