Hydrolic dump wagon
/ Hydrolic dump wagon #1
fivazpond
Upstate New York
John Deere 585x
I am looking for a small dump wagon for a 29hp compact tractor I am purchasing- I plan to have rear hydrolics for the hook up. Anyone have any recommendations?
/ Hydrolic dump wagon #3
I suggest you consider a "dual power" wagon. I had one built that had the standard battery powered pump to run the hydraulic cylinder and a valve that allows the tractor's hydraulics to run the cylinder. If you'll be using a hydro tractor, make sure the the hydraulic fluid in the trailer's system uses the same fluid as the tractor.
With a dual system the trailer can be used behind a truck or other tow vehicle. Most of the trailer builders should be able to furnish what you want. Appalachian in Ohio is one that will build anything you spec.
/ Hydrolic dump wagon #4
A wood bed will be destroyed quick if you plan on dumping rocks with it. A new steel dump trailer starts around $3K. Look at auctions, I picked this one up for $800. 5x9 have dumped 3+ yards of heaping clay per trip.
SKID STEER PLATE GRABBER (A62613)
SKID STEER PLATE...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
Steel Wheelbarrow (A65640)
Steel Wheelbarrow...
1939 Chevrolet Deluxe Coupe (A65640)
1939 Chevrolet...
