Toplink hydro top link
/ hydro top link #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
Why is the hydro top links so much more than a regular tie rod style?:confused::confused:
Any ideas on adapting the cheaper ones to the ball ends?
/ hydro top link #2
Good question. I just bought a 6' box blade and I can see why you need a hydraulic link. So why are they 150+ dollars when a conventional tierod cylinder is under $100?
I'm going to put a sleeve in the attachment end to run the 1" hole down to the 3/4" pin for the BB and then weld a top link swivel to the bare rod end of a TSC cylinder. That way I can get the lenght and stroke I need rather than settle for a part that's generally too long. Most H.top-links are 20" contracted.
Note that the $170+ H.top links have check valves to prevent leak down. BFD.
/ hydro top link #3
First-You don't want a tie-rod cylinder for a HTL due to the limited room most machines have, a welded cylinder is best and it cost's more.
Second-I think they cost more because of the ball/swivel ends they have welded on, there is just not a huge market for cylinders with these ends-so they sell less units making the cost higher.
You can certainly get a regular welded cylinder and weld the proper ends on if you are qualified to do so...but most are not and happily pay the $$$ for the correct cylinder.
/ hydro top link
/ hydro top link #7
I went the Surplus Center route, but learned that the cast part on the tractor was too narrow for the SC ball swivel to fit.
I bought the one that fit, and couldn't be happier. Shown before hoses connected, and before painting black.
/ hydro top link #8
Beenthere:
Your tractor looks like my 4200 with the Surplus Center cylinder. Mine came painted dark gray, so I left it alone. I just wish the rod was 1" diameter instead as the cylinder housing is just a bit big and rubs on my PB & SCV quick-connects if I'm not careful.
Picasa Web Albums - Matt - Top-n-Tilt#
/ hydro top link #9
My first hydraulic top link and tilt cylinders were tie rod cylinders that I welded new ends on.
I later upgraded to the cylinders with check valves. Well worth the extra price in my opinion. These cylinders work SO MUCH better than the tie rod cylinders I had.
No more leakdown and the top link holds its position much better when under load boxblading.
I'll take the welded cylinders with checkvalves hands down anyday.
/ hydro top link #10
I just got a hyd toplink that I have plugged into one of my rear remotes. I don't know how i did without it. It is fantastic for what you were saying , attaching implements, grading. and I just picked up a crane/boom where it helps with that . My valves on my remotes are sensitive so I can feather it for fine adjustments easily. I got mine through Dalton. Cost a little more shipping to Can. but it was worth it. This one does not have a lock valve but my remote valve has a full off detent and so far no leakage past so the cylinder stays where you leave it
Hydraulic Top-Link - Category 1
Crane/Boom
3pt Crane/Boom-With Video - TractorByNet.com
Dave
2013 CHEVROLET CAPRICE CAR (A66091)
2013 CHEVROLET...
84" Smooth Shell Kit (A68134)
84" Smooth Shell...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2001 SPARTAN GLADIATOR T/A FIRE TRUCK (A66091)
2001 SPARTAN...
2019 Nissan Sentra Sedan (A66738)
2019 Nissan Sentra...
Chariot Scrub 20 Electric Floor Scrubber (A64194)
Chariot Scrub 20...
