Oil & Fuel Hydro oil question
/ Hydro oil question #1
BlackRaptor
SEMN
John Deere 3320
I changed the hydro oil in the 2520 this weekend.
and i have to say the manual is worthless.
anyways I put 4 gal ran it around a little and could only see fluid at about 1/4 to 1/2 on the sight glass book said 3/4 or a bubble on top. so i added a half gal more and it seems to have filled the site glass.
i'm wonder if i over filled it.
how much did it take to fill yours?
I don't want to use it if it's over filled and hurt something.
THanks guys.
/ Hydro oil question #2
If it was a gallon or more I would drain some but what's probably only a quart or less over full I wouldn't worry about it.
/ Hydro oil question #3
I had the same problem with my 2320 and I have left it alone. Over-full does not seem to be a problem as long as it's not leaking back out the fill plug.
/ Hydro oil question #4
Is it a common sump machine? If so.. many can be overfilled to account for external hyds.
My NH 7610s can take about 3 gallons more in the sump than it needs for just the tractor.. etc.
soundguy
/ Hydro oil question #5
Wouldn't worry... should be just fine.
I've noticed that whenever I dropped my FEL or the backhoe attachment (BH the most..)the hydro fluid levels would vary by a couple of quarts at least.
As long as the levels are in the "operating range" on the dipstick or sight glass - good to go.
AKfish
Thanks for the help I'll use the tractor tonight and then recheck everything.
i'm sure it's just fine just such an expensive machine i don't want to mess it up.
Thanks again.
/ Hydro oil question #7
Raptor,
Mine came that way from the dealer, i.e., the sight glass was full and no bubble was visible. I ran it like that for the first year/50 hours, with no problems. I think I put back in the same amount you did (minus a little that was left in the final drives which I didn't drain because of the worthless manual...).
So, agree with those who say you're probably OK.
/ Hydro oil question #8
I am one of the ones that overfilled my 2320 until it was pouring out the fill hole waiting for the sight glass to fill up..
I ended up draining enough so that when running it disappeared out of the sight glass, but was in the sight glass when stopped...
BTW - Does anyone know if the JD Low viscosity Hy-Guard is a synthetic? I used Amsoil when i did my 50 hr change, because I thought it was the JD dino... Someone on 'bob is the oil guy' said that it was synthetic though..
Brian
2019 CATERPILLAR 289D SKID STEER (A65056)
2019 CATERPILLAR...
AG Tires - 11.00-16SL (A68134)
AG Tires -...
2018 DODGE RAM 5500 HD SERVICE TRUCK (A65057)
2018 DODGE RAM...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2002 Sterling M8500 Acterra Landscape Dump Truck (A66736)
2002 Sterling...
2013 5x8 Port City S/A Enclosed Cargo Trailer (A66738)
2013 5x8 Port City...
