Hydro help
/ Hydro help
Tell me kenmac! I learned about hydros the hard way. Lesson learned
/ Hydro help #132
I'm just wondering how the threads got damaged on the pump shaft. It would be apparent someone was in that pump before. When you get the Key make sure you look and check the Hex Bolt and were the key goes. That is what going to take the most damage. It's not made any were near the grade or metal the pump shaft is. It would be hard to believe the Hex bolt keyway isn't damaged.
/ Hydro help
Maybe I did the threads. I used an impact gun. Only way to get it off. There was nothing to grab to hold the shaft.
/ Hydro help #135
Check the Hole in the end of the shaft when putting it back together. It's there for a reason. Most likely takes allen wrench. Or did at one time. Just because if you shear the key you need something to hold the shaft and get the nut off. Or risk the damage just like what happened to the threads.
/ Hydro help
Lol see I'm learning I seen that hole. I feel like a doe doe now.
/ Hydro help #137
Oh no at least your learning. I just worked in a machine shop and multi million dollar printing equipment for 35yrs.. There's a lot who just will never learn. LOL.
/ Hydro help
I hear ya ! By the time I get this all fixed I will be the hydro master. I can't tell all you enough how much I appreciate all of you helping and taking the time to help a newb small farmer tractor owner!
/ Hydro help
Just received 2 parts
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Broom Attachment (A59228)
Broom Attachment...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2019 Chevrolet Silverado 1500 LT 4x4 Crew Cab Pickup Truck (A59230)
2019 Chevrolet...
