Hydro help
/ Hydro help
Tell me kenmac! I learned about hydros the hard way. Lesson learned
/ Hydro help #132
I'm just wondering how the threads got damaged on the pump shaft. It would be apparent someone was in that pump before. When you get the Key make sure you look and check the Hex Bolt and were the key goes. That is what going to take the most damage. It's not made any were near the grade or metal the pump shaft is. It would be hard to believe the Hex bolt keyway isn't damaged.
/ Hydro help
Maybe I did the threads. I used an impact gun. Only way to get it off. There was nothing to grab to hold the shaft.
/ Hydro help #135
Check the Hole in the end of the shaft when putting it back together. It's there for a reason. Most likely takes allen wrench. Or did at one time. Just because if you shear the key you need something to hold the shaft and get the nut off. Or risk the damage just like what happened to the threads.
/ Hydro help
Lol see I'm learning I seen that hole. I feel like a doe doe now.
/ Hydro help #137
Oh no at least your learning. I just worked in a machine shop and multi million dollar printing equipment for 35yrs.. There's a lot who just will never learn. LOL.
/ Hydro help
I hear ya ! By the time I get this all fixed I will be the hydro master. I can't tell all you enough how much I appreciate all of you helping and taking the time to help a newb small farmer tractor owner!
/ Hydro help
Just received 2 parts
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
John Deere 1025R (A53317)
John Deere 1025R...
Topsoil Trommel (A57453)
Topsoil Trommel...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
