Hydro help
/ Hydro help #101
The tractor should be fine running right with out being connected ?
Just to be real clear - Until you get a loopback hose installed you can't start the tractor to drive it over near the plow.
If the tractor and plow are still close enough to re-attach the plow's disconnects back onto the tractor - then in that case the fluid would have a return path, and you could test the pump.
Don't start the engine without some sort of a loopback path for the fluid.
/ Hydro help
Great! Thanks for clearing that up! After I dropped the plow I did drive it around some. I didn't know
/ Hydro help #103
will be interesting to see what if anything you broke by doing this. Looking at your pump, I don't see where a key would go.. Hoye may have been able to answer this for you
/ Hydro help #105
The pump was dead headed so key will be sheared. If it isn't the pump probably copped it and may not pump properly.
/ Hydro help
Today I will take the pump back out and look for the key. I will take pics.
/ Hydro help
The other thing that is weird is that I do not see the o ring or the gasket from pump to motor.
/ Hydro help
I see the key on that pump as well but there is no slit on that nut for a key.
/ Hydro help
2025 Swict 66in. Skid Steer Bucket Attachment (A59228)
2025 Swict 66in...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
BUYERS PREMIUM & PAYMENT TERMS (A59908)
BUYERS PREMIUM &...
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
