Hydro help
/ Hydro help
Yes the hose that will work is like 4ft. Long. I could take it off and try it. I'm just freaked out I don't want to blow this pump
/ Hydro help #92
Post #54 you shown the two hose ends. Plug them together and your loop is done.
/ Hydro help
That is on the snowplow that is off the tractor. I can take one of those hoses on the plow and put the other connector on the end and plug it in. I will give it a try.
/ Hydro help #94
Mighty confusing. Does your diverter block on the tractor just have quick connects screwed in it or hoses coming off it with quick connects?
/ Hydro help
/ Hydro help #96
My bad, I went back to the beginning of the thread and see the connects screwed into your block. Do whatever neccesary to loop those two together. :confused3:
/ Hydro help #97
The 186 parts manual does not show a key under the hex drive but Hoye shows a key for it. I would remove the nut and hex drive and take a look for a key, sheared maybe. HYD. PUMP SHAFT KEY_: Yanmar Tractor Parts[/QUOTE]
I don't understand. Are you saying there is a Shaft key underneath large Hex Bolt? That would mean the large Hex bolt would spin then just by Holding the smaller Nut? If the key was Sheared?http://www.tractorbynet.com/forums/...-imageuploadedbytapatalk1456944389-293376-jpg
I'm pretty sure that is a key Visable. HYDRAULIC PUMP: Yanmar Tractor Parts Or really any need for a key then??
/ Hydro help
I just ordered keys, o rings and the gasket. So I will have them. Also got the hour cable hopefully that fixes my meter to.
/ Hydro help
Another question. So if this works there will be air in the system. Any problems with that? Do I have to bleed it somehow?
/ Hydro help #100
Make sure that your quick disconnect is not dirty/blocked and has completely closed. And be sure your control levers are not sticking.
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
1607 (A57192)
1607 (A57192)
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A59230)
2008 Ford F-550...
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
