Hydraulics
/ Hydraulics #1
Mcfclz
Bristol ct
Kubotab7100
I have a belt driven hydraulic pump on a case 442 with a FEL when ever I engage the value the pump squeals & motor bogs down. What is causing this & how could I correct the problem!! Your suggestions!
/ Hydraulics #2
Is there a pressure relief valve somewhere in the hydraulics?
It sounds like the pump is stalling due to low or dead headed flow.
If you ask a moderator to move this post to the the Hydraulics section in General Forums, or just post again there, you will get better and more help.
http://www.tractorbynet.com/forums/hydraulics/
/ Hydraulics #3
What is attached to the work ports on the valve?
If you are at the end of cyl travel, the relief will activate.
If a hyd motor is fully loaded, the relief will go off.
You may have a QD loose and can not pass the fluid to where it supposed to go.
If you have a cyl on the work ports, is the cyl moving.
/ Hydraulics
Work ports have cly connected, cly move very slowly when value is engaged
/ Hydraulics
I have a chief directional 4way value 3 pos. tandem center
/ Hydraulics #6
Speed of operation is based on pump GPM , so if you pull the lever back, what happens?
/ Hydraulics
I have a concentric gear pump 4-8 GPM driven by 18 hp vanguard
/ Hydraulics
When lever is engaged pump squeals & motor bogs & cly move slowly
/ Hydraulics #9
You might put a hyd gauge in the valve and check out the pressure.
Is the cyl connected to anything and is it binding/bent, etc..
/ Hydraulics
Clys are connected toFEL bucket & bucket frame
2011 Mercedes-Benz E-Class Sedan (A59231)
2011 Mercedes-Benz...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
2015 Jeep Cherokee 4X4 SUV (A59231)
2015 Jeep Cherokee...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
