Hydraulics
/ Hydraulics #1
Dirtfarmer456
Charleston,WV
Ford601
I have a Ford 601 hydraulics just stopped working. What is most common cause? Is there an easy way to check and see if pump is pumping?
Thanks
/ Hydraulics #2
Older tractor did you check the fluid?
/ Hydraulics
Yes DABSGT checked fluid dipstick shows a little over full.Is there an easy way to see if pump is pumping ?
Thanks
/ Hydraulics #4
On my NAA (and I think your 601 is the same) there is a little plate on top of the hdyraulic under the right front corner of the seat that is where you mount the valve for remote hydraulics. If you removed that plate and cranked it over I would think you should make a big oily mess if the pump is working. The plate is about 3 or 4 inches across and has a hump in the middle. I hope this helps.
/ Hydraulics #5
I was just out and looked at our NAA. On it the hyd pump drives off the flywheel. On it you could disconnect the pressure line (small line) and see if it pumps out fluid.
/ Hydraulics
Thanks for the info Oldtractorfixer Iwill check that plate under seat. The lines are all internal. Thanks again forthe info.
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
2018 Bobcat S-570 (A63689)
2018 Bobcat S-570...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
10'' PALLET FORK EXTENSIONS (A61572)
10'' PALLET FORK...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
2020 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A61573)
2020 Peterbilt 579...
