Hydraulically driven PTO
/ Hydraulically driven PTO #1
acadie1
burton, New Brunswick
case 430, case 520
Is there such a thing as a self contained PTO unit, driven by hydraulics that can be mounted on a tractor? This would for tractors like some older industrial tractors that don't have a PTO, Tractors where the PTO is defunct and parts are unobtainable or just too expensive, or maybe where somebody needs an additional PTO, like on the front of the tractor. I seem to remember seeing some at one time but searching online didn't come up with any thing.
Thanks in advance
/ Hydraulically driven PTO #2
It won't do you much good, but it'll serve to keep you looking. I own an ingersoll, which is all hydraulics. I did find (but did not purchase) a hydraulically powered 1-3/8" 6 spline PTO. It would have require mounting it, which I couldn't solve. That may mean it does not meet your requirement to be "self contained". Good luck in your search
/ Hydraulically driven PTO #3
What are you going to drive this hydraulic PTO with? If you have the flow and pressure available all that is required is a hydraulic motor sized to provide 540 RPM based on pump flow available. Depending on tractor could also require a valve for rundown.
Similar to people wanting to convert PTO driven snowblower or rotary mower to hydraulic drive.
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
More info coming soon (A61574)
More info coming...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
John Deere 410D Backhoe (A62679)
John Deere 410D...
429835 (A61166)
429835 (A61166)
