Hydraulic winch question
/ Hydraulic winch question #1
bdog
Elite Member
Texas
John Deere 6130M
I have a rubber tracked crawler that I want to put a hydraulic winch on. It originally was a crawler dump with a tilting dump bed but now it has a fixed flat bed and I now have an unused hydraulic circuit with a control in the cab that used to operate the tilt bed. I checked with the manufacturer and it puts out 11 GPM @ 3000 PSI.
I am a little fuzzy on how hydraulic motors work but doesn't the pressure dictate the torque and the GPM just dictate how fast it turns? The winches I am looking at list in the specs 20 GPM @ 3000 PSI. If I bought one of these would it reach the stated line pull but just be about half as fast? I would not be using it all that often just when I get stuck which doesn't happen that often.
/ Hydraulic winch question #2
Yes pressure dictates torque & flow dictates speed. Like you state will run a little slower but generate the same line pull
/ Hydraulic winch question #3
I was going to put a hydraulic winch on my dozer which produces 13.5 GPM at 2000 psi. But when I figured out that it is 13.5 GPM at full throttle and the winch would be deathly slow I got discouraged. Running at about 1500 RPM it would be about 1/2 as fast. For occasional use it would be fine but I wanted something more everyday useful. If you put it on let us know how it turns out.
gg
1988 Ford Mustang GT Convertible (A61574)
1988 Ford Mustang...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
LILLISTON 8R ROLLING CULTIVATOR (A63291)
LILLISTON 8R...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2022 John Deere 616R Sprayer (A63111)
2022 John Deere...
