3-Point Hitch Hydraulic top link
/ Hydraulic top link #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
WOO-HOO! Finally got a hydraulic toplink and installed it today. Works great! Next will be a hydraulic side link, but that will be a while.... they are crazy expensive!
/ Hydraulic top link #2
Awesome! :thumbsup:
Is that from the fella on here who builds them?
(sorry, I forget the guys name. :( )
/ Hydraulic top link #3
Curious about the proportioning or diverter shuttle valve that's on there. Can someone tell me it's purpose. How much was that setup?
/ Hydraulic top link #4
Just as a price point, Agri-Supply is where I got mine. It doesn't have that valve setup and I'm struggling to figure out why that's needed. But a Cat II is $176 and the hoses there were about $25 each. I had to get 2 NPT to ORB fittings.
/ Hydraulic top link #5
The valves on top are double pilot check valves...they prevent the cylinder rod from moving when there is no fluid flowing in or out...it keeps the top link rigid... A hydraulic top link can be made to do the same without a check valve by disconnecting the hoses from the remotes...
/ Hydraulic top link #6
Mine doesn't move. Of course my tractor is new. Why would it move? Leak down?
/ Hydraulic top link #9
Is that the 18 1/8" - 26 3/8", 06003? I see that number in the 2nd picture.
/ Hydraulic top link #10
Sorry if I'm hijacking here, but perhaps someone can explain.
Can you do a hydraulic side link with a rigid top link? It seems to me a hydraulic side link would be more useful than a top link (primarily used for road grading).
I only have one free rear remote, so ...
Or, is there a way to get top and tilt with only one valve?
/ Hydraulic top link #12
As someone who does not currently have a hydraulic 3-point anything, I feel completely justified in answering this question as a complete novice.
I find that I adjust my top-link WAYYY more than I adjust my side-link. However, I do more mowing, box scraping, rototilling, etc, than I do grading my driveway (and it shows!). However, I do have a back blade, that when adjusted at an angle, the side link must also be adjusted for the correct positioning. Your mileage may vary. For me, I'd get both, the top and tilt, but if you only have one remote, then you are stuck with one or the other. Unless you wish to unhook the hydraulics from one, hook to the other, make your adjustment, rinse and repeat. But I think that would most certainly defeat the purpose of having hydraulic links. I'd look at possibly installing a second (and third while your there) hydraulic remotes on your machine.
/ Hydraulic top link #13
I have looked at installing an extra remote, but my understanding is that the XR4145 does not have that option. The problem is I need one for snowblower control in the winter.
Perhaps an option would be disconnect from the top or side link when the snowblower is on (I'd have no need for it then), as it sounds like then it would just behave as a rigid link?
/ Hydraulic top link #14
Here is a single factory rear remote turned into 4 useful sets of couplers using 3 electric diverters, all adjustments at the tip of my fingers using a single control lever and 3 separate switches in the control grip on that lever. :thumbsup:
/ Hydraulic top link #15
Holy rear remotes, batman!
Is that something you bought and plumbed yourself, of was it a kit you were able to purchase?
Yes it is. Works really well. On my box blade, it will drop the rippers down 4" with it retracted. Fully extended, it will roll it back onto the rear facing blade for fine smoothing. A perfect fit!
/ Hydraulic top link #17
Ted, you’re gonna find that most useful.
/ Hydraulic top link #18
I have an XR4145, 3 sets remotes, Dealer installed
/ Hydraulic top link #20
I have two on my XR4145. I'd like a third, but probably can work around it.
Brians idea on the diverter valve might be a solution too.
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2025 MB27 27in Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 MB27 27in...
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
