hydraulic thumb
/ hydraulic thumb #1
apatche1964
john deere 955
I have a terex hr 16 mini excavator i want to build a thumb for it. It would sure be nice to have some drawings and design ideas , any ideas?
/ hydraulic thumb #2
Im in the same boat. I was given a backhoe from a family member, and have been looking around the net. I think Im going to wing-it and make my own. Not sure if it is going to hydraulic or not.
/ hydraulic thumb #3
I thought these looked good!! Click on the work tab to see the excavator thumbs.Home
DAVID,
/ hydraulic thumb #5
Before you spend money on steel to build a thumb, check out Bro-Tek: Tractor Add Ons. I bought one last Fall and couldn't be happier with it. Mine is on a Woods Groundbreaker on a Kubota L2250. According to Richard at Bro-Tek, he can fabricate a thumb for any backhoe. I don't think you can design, purchase the high quality hard steel and bolts and build a thumb for the price of the Bro-tek, approx. $300. There are plenty of pics and videos on u-tube and other forums. The unit bolts on in minutes and works perfectly. No one has been able to explain why it is necessary to spend lots of money for a hydraulic thumb when the bucket does all the work. The hydraulic unit on a thumb is only used to adjust the position of the thumb. I set my thumb in the desired position by adjusting the top link and have never had to move it. If you want the thumb totally out of the way, it takes one or two minutes to pull the pins, rotate the thumb up against the boom, replace the pins, throw the top link on the tractor and you are ready to go. Good luck.
/ hydraulic thumb #6
Looks like a nice product
no cylinder and no grease zerks though
/ hydraulic thumb #7
If it's not in the budget for a hydraulic then it's understandable. However, once you use the hydraulic setup you wouldn't want to go back. I've spent alot of time sorting out a rock pile. When you are picking from the top of the pile you want the thumb at one angle, once you get lower you have to adjust it. There are times when you try to curl the bucket to get something and it's too wide to grab so you have to back the thumb off. It's nice to be able to just hit a lever. I had to tap off my hydraulics block with a new port and lever. Once that it hooked up it's only 2 lines. Alot of you guys have it easy cause there is already extra ports you can plug into. If you have to do any welding to the dipper arm for a thumb, then wait till you can afford what you really want. I would hate to weld for a manual thumb then turn around and cut it off down the road for a hydraulic cylinder.
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2014 Hagie DTS10 Sprayer (A63111)
2014 Hagie DTS10...
1995 CUSHMAN TURF HAULER (A64280)
1995 CUSHMAN TURF...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
2015 KOMATSU PC360LC-11 EXCAVATOR (A64279)
2015 KOMATSU...
