Hydraulic Tee valve...
/ Hydraulic Tee valve... #11
So Rick does that mean my last statement is incorrect? I'm still trying to understand CCLS.
Thanks,Jim
Jim, You are incorrect.
The quirks and differences between open, closed, and ccls systems end at the spool valve so long as the spool valve is normally closed and used to control one (or in this case multiple) functions. The following applies to splitter valves only, not a downstream spool valve such as we discussed today in another thread. THIS particular poster wants to use a remote valve to control two functions independently. That requires a simple splitter valve with two ports recieving oil from the tractor remote and sending it back. And four ports, two each connected to each in/out port. A single spool directs flow from the tractor to one pair of work ports while blocking the other pair. This valve will receive the same controlled flow from the tractor remote whether the tractor is OC, CC or CCLS. Clear as mud? Let me know.
Fasse Valve - 2010 Consumer
/ Hydraulic Tee valve... #12
Rick
How is OP's hyd question different from a FEL with open center 2 spool valve plugged into the factory remotes of a CCLS? Maybe the difference I'm overlooking is in your statement "controlled flow from tractor remote"???
Thanks,Jim
/ Hydraulic Tee valve... #13
The cyl do not care where the fluid comes from.
That is what he trying to do , control two cyl.
/ Hydraulic Tee valve... #14
Rick
Thanks,Jim
That's the key. The tractor's remote valve is controlling the direction & flow here. In the case of a downstream valve, the tractor remote is providing flow but control is selected by the downstream valve. An open center valve will work here at the expense of the other remote valve which can do no work when pump flow is returning to tank. In the other thread, the poster really wanted to install a new joystick valve in parallel with existing CCLS remotes. That requires a CCLS joystick valve and proper connections.
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2000 Kubota KX61-2 (A60462)
2000 Kubota KX61-2...
2020 Deere 544L (A60462)
2020 Deere 544L...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR4AJ276527 (A61165)
2010 International...
1996 Lincoln Town Car Sedan (A59231)
1996 Lincoln Town...
