Hydraulic Question
/ Hydraulic Question #1
HeartBeetsFarm
Berkley, MA
Branson/3510
I have a Deere 5065E with one set of rear remotes. I currently use it mainly for a hydraulic top link, but I also use it to a run a plastic mulch winder. However I have to hold the lever down to keep the fluid flowing. I recently purchased a new root digger and will be using the remotes for the same purpose to move the chains. It gets a little old holding down the lever, but its not a big deal.
Should I be looking to add another set of remotes or is it fine to use my current set up? If adding another set, which type?
Thanks in advance.
/ Hydraulic Question #2
You're probably better to add another set of remotes so you don't have to constantly change between top link and implement.
Probably a remote with detent function. The lever will stay in position in whatever direction you choose.
Or one with spring return, like the one you have, and just use a bungee cord to keep pulling the lever.
/ Hydraulic Question #3
When I added remotes, I put on two without detents for my top and tilt cylinders and a third with a detent to run a post pounder. My application is similar to yours, when I'm using the pounder I want the remote valve to stay on all the time because the pounder has a separate valve at the operators station to make the ram go up and down. As the other poster said you could just use a bungee cord, that works too.
/ Hydraulic Question #5
Is there such a thing as too many remotes? :D I have three on my Ford.
A detent kit can be added to most valves. I've seen them sold separately. They replace the rear cup on a valve body.
East Texas Gooseneck Trailer (A65563)
East Texas...
KUBOTA 60" PIN ON BUCKET (A64280)
KUBOTA 60" PIN ON...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2010 New Holland Boomer 8N (A62613)
2010 New Holland...
