Hydraulic pump problem
/ Hydraulic pump problem #1
robbmw535
I have a 2020 gas JD. The hydraulic pump is not putting out much flow and it looks as if air is whipped into the oil. IS there a primer pump that feeds the external hydraulic pump. Can you bleed the air out of the system? What is wrong with this tractor?
/ Hydraulic pump problem #2
Sounds like either water in your hydraulic oil or a leaky return line drawing in air bubbles.
/ Hydraulic pump problem #3
What he said:D
Oh, and the system should be self-bleeding.
And, Welcome to TBN:D
Does this tractor 2020 have a primer pump in the transmission or just the main external pump?
If there is no internal primer pump could the main pump be pulling in air due to a leak in the pump?
Thank
/ Hydraulic pump problem #5
If the oil is a milky color, then it has some water in it. As far as the bubbles, air is being sucked in , possibly from the filter, a loose fitting, or pump seal. The return usually goes back to tank, and doesn't have a whole lot of suction,
So one told me I should check the hydralic filter and change the oil. If the filter is clogged this could cause the problem, does this sound correct. What type of oil do I use for this JD?
Thanks
Rob
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Unused 2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2100 GAL WATER TANK (A68842)
2100 GAL WATER...
2000 KENWORTH T800 CRANE TRUCK (A67714)
2000 KENWORTH T800...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
CAT 315CL Manual Thumb (A68134)
CAT 315CL Manual...
