Hydraulic pump problem
/ Hydraulic pump problem #1
robbmw535
I have a 2020 gas JD. The hydraulic pump is not putting out much flow and it looks as if air is whipped into the oil. IS there a primer pump that feeds the external hydraulic pump. Can you bleed the air out of the system? What is wrong with this tractor?
/ Hydraulic pump problem #2
Sounds like either water in your hydraulic oil or a leaky return line drawing in air bubbles.
/ Hydraulic pump problem #3
What he said:D
Oh, and the system should be self-bleeding.
And, Welcome to TBN:D
Does this tractor 2020 have a primer pump in the transmission or just the main external pump?
If there is no internal primer pump could the main pump be pulling in air due to a leak in the pump?
Thank
/ Hydraulic pump problem #5
If the oil is a milky color, then it has some water in it. As far as the bubbles, air is being sucked in , possibly from the filter, a loose fitting, or pump seal. The return usually goes back to tank, and doesn't have a whole lot of suction,
So one told me I should check the hydralic filter and change the oil. If the filter is clogged this could cause the problem, does this sound correct. What type of oil do I use for this JD?
Thanks
Rob
2000 FREIGHTLINER FL80 WATER TRUCK (A67714)
2000 FREIGHTLINER...
Fuel Storage Tank (A68134)
Fuel Storage Tank...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2016 FORD F-150 (A67714)
2016 FORD F-150...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
Gehl RS6-34 (A64119)
