Hydraulic Pump Dead?
/ Hydraulic Pump Dead?
Cost? :) what's cheaper.. a pail of oil..or the pump plus downtime.
My big fords hold somthing like 13g of hydro oil.. and it usually comes out darn good looking.. but it's cheape rthan a 1000$ pump, plus flusing all the lines and cleaning all the valves AND then changing the oil and filter. :)
soundugy
I agree.
After my knee-jerk panic that my pump was dead, the cost of the extra fluid is minimal.
What do you recommend for the oil/diesel mix?
/ Hydraulic Pump Dead? #22
When I flush a sump that has been wet or dirty, i always add in some trans tune/seafoam.. or some 90% isopropyl alcohol, plus oil, plus some diesel, then circulate it a bit, then dump.. the seafoam or alc, grabs any free water and holds it in soloution.. the diesel thins it all out and makes it so any debri or suspended particles will run out fast vs settling. the oil is there for some lube and some viscosity and to up the vapor pressure to prevent cavitation that straight diesel would likely cause.
if a sump holds say.. 5g normally.. I usually short it and dump in say.. 3 or a hair more.. just enough to get things going.. and I usually do 50/50 oil/diesel mix.
soundguy
/ Hydraulic Pump Dead? #23
WOW Soundguy..., wish you were closer..!! I'd gladly bring you a barrell to fill when you service your tractors... That stuff burns great in my waste oil furnace..!!
My neighbor is a stickler for changing his hydraulics in his Cat D4 and JD 410 Hoe. That's good for a 55 gallon drum a year, plus engine oil services.
Between him, a couple buddies, and my oil, I stay just pretty toasty in the shop all winter.
So if some of you in the northern regions are worried what to do with your used oils... Guys like me will gladly take it..!! Post it on Craigslist, etc. I usually collect a year ahead of time. Gives the water time to settle out. I've got ball valves on my storage tanks, and crack them in late September, to drain any water off...
/ Hydraulic Pump Dead? #24
yep.. between my 2 laqrge tractors.. it's 26g of just hydro oil.. then another 5.5g of crankcase oil. add in my other machines that have about 6.5g of total oil in them each... and it adds up!
soundguy
/ Hydraulic Pump Dead? #25
Change your oil, dump in a couple bottles of isopropyl. I would clean the suction strainer too.
Hmm, so it was icing up. Nah, couldn't have been icing up! Well at least that was what was suggested. Should have put a gauge on it. ;)
/ Hydraulic Pump Dead? #26
I agree.
Why not save some of that hyd fluid, and let it sit up for a couple of days in a mason jar. You might want to send a sample in for testing just to be sure about things.
I don't know the cost for testing, but someone on probably does.
/ Hydraulic Pump Dead? #27
Freezing hyd fluid.
Glycent 46 Hydraulic Fluid has a freezing point of -57 degrees Celsius, which is -70.6 F
/ Hydraulic Pump Dead? #28
It's happened to me more than once. After thawing out, I would work it until warm and drain the fluid. Replaced with lower cost fluid and worked it long enough to warm again and drain. Refilled with proper fluid and no more problems. I do store it in a barn now, so that helps. Seems fairly common up north, on older tractors especially.
since water in the fluid usually turns it milky and seems less likely to freeze, I assume it is from the cold/warm/cold cycles causing condesation to drip off the interior, and the droplets sink through the fluid without mixing. Then the cold days freeze it in the bottom before having a chance to mix with the fluid. I've had it happen and then after thawing it worked fine for the rest of the winter even after much colder temps. Cold/warm/cold cylcle, that's my theory. If it was a few degrees warmer before you started it, the water would have been thawed again and blended into the fluid for good.
/ Hydraulic Pump Dead? #29
I also had this happen to me on a log splitter.Left a friend use it & he wanted to do me a favor and pressure wash it down,well he got to close to the vented fill cap and must have really been putting the water to it because the hyd.tank was full to the top with water. I found this out when i needed to use it was in the single digets i couldnt even pull the rope to start it.Got to looken yep froze up.It had a 2" thick slab of ice in the bottom of the tank that i found when i got the oil out with a ladle (lots of dipping)nothing would come out the bottom outlet pipe.Heated the tank got the water out drained all the lines,pump,valve,cylinder etc.....Filled back up ran splitter repeated the draining process $90.00 later in fluid it worked fine.(The tank had ice in it,the pump,lines,filter,cylinder,valve had a milky thick molassis like fluid.)I had to heat eveything to get it to drain.
/ Hydraulic Pump Dead? #30
soundugy
Soundguy,
What do you use to catch the oil when you do your change? If I remember right, the 2240 I bought holds 16g.
Freezing hyd fluid.
I don't think anyone was suggesting that the hyd fluid froze. I took it that the water and oil separated and the water froze.
Whatever happened was directly related to temperature because that's the only thing that changed.
/ Hydraulic Pump Dead? #32
Soundguy,
I normally use the cut out bottom of a 55g drum that fits under the tractor.. sometimes when it's in use elsewhere, i use about 4 5g buckets, and do the bucket brigade thing when I get about 4g in them.
At least than once this has resulted in me getting alot of oil on me as I dropped the drain plug into a bucket, and for some reason couldn't get my hands on the next bucket.. :)
sure took care of that dry skin problem I was having down one side of my body!
soundguy
/ Hydraulic Pump Dead? #33
That was just a ref to the freezing point of hyd fluid. I haven't been able to find any studies on emulsified water/hyd fluid freezing point, and the harmful results, if any.
Water will help to change the characteristics of the hyd oil to make it less than ideal for the proper operation of pumps and and all things hydraulic operated.
/ Hydraulic Pump Dead? #34
soundguy
Last question. What do you do to get rid of your old oil?
/ Hydraulic Pump Dead? #35
Most towns have businesses that collect old oil for recycling or burning. It cost me $25 to get rid of a 55 drum of unknown blend of old oil. They came out with their truck and sucked the oil from the barrel. They might be the same people that take away the old cooking oil from restaurants, etc. Some people try and make bio-diesel from the cooking oil.
/ Hydraulic Pump Dead? #36
Thanks JJ.
/ Hydraulic Pump Dead? #39
I pour or pump mine into a 55g barrell, then haul it to work when full.. we have a bulk collection tank there.
soudnguy
/ Hydraulic Pump Dead? #40
soudnguy
I'll check with the mechanics shop at work at the city. If we don't pay to get rid of it, I may be able to do something similar.
LOOK! (A63109)
LOOK! (A63109)
CAT CB-334E Smooth Drum Roller (A61166)
CAT CB-334E Smooth...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2016 JOHN DEERE 310L BACKHOE (A62129)
2016 JOHN DEERE...
2014 REITNOUER 48FT T/A FLATBED TRAILER (A59909)
2014 REITNOUER...
24ft Flatbed Gooseneck Trailer (A61166)
24ft Flatbed...
