Hydraulic problems
   / Hydraulic problems #1
jwmoore
United States
Yanmar 2220D
I have a Yanmar 2220D with a Koyker 155 fel. The bucket takes forever to tilt back. It tilts forward and goes up and down like it is suppose to. I have replaced the control valve and changed the hydraulic oil and cleaned the strainer. Any suggestions?
   / Hydraulic problems #2
Are the loader hydraulics attached by quick connects?
   / Hydraulic problems #3
Sounds like one or both piston seals may have failed. Does it improve with higher engine speed? Is it worse with a load in the bkt? If one or both seals are bypassing, you may be able to hear it if you stand close, or feel the flow with your hand.
   / Hydraulic problems #4
If you can check the temp on each cyl above and below the piston. Should tell you real quick after it has ran long enough to get good and warm.
   / Hydraulic problems #6
Actually the most temperature rise will be right at the piston. This is a great mess free troubleshooting method. As little as 5 degrees of temp rise as compared to the rest of the barrel has been 100% successful for me over many years.
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
ECHO SRM-2120 GAS POWERED WEED EATER (A51244)
ECHO SRM-2120 GAS...
