3-Point Hitch Hydraulic problem
/ Hydraulic problem #1
rosso01
Chesapeake, a.
JD 850
I have a 1987 John Deer 850 tractor that was working fine before I changed the Hydraulic fluid. Now, the three point hitch raises up every time I start it and you have to hold the lever down to lower the hitch. Is it air trapped somewhere? How do you bleed these tractors?
Thanks
/ Hydraulic problem #2
Air will bleed by cycling 3 pt hitch up/down. Is the friction mechanism(parts keys 19-26) snug on the control handle.
/ Hydraulic problem
Thanks Jim,
I guess this is not a bleeding problem, we have been working it up and down all day. I looked and found the friction mechanism is completely missing, i can fix that. There is a knob under the seat that has open and close on it. It looks like an outdoor garden hose type. Does anyone know what this is?
Tanks for your help.
/ Hydraulic problem #4
There is a knob under the seat that has open and close on it. It looks like an outdoor garden hose type. Does anyone know what this is?.
Knob is 3 pt rate of drop screw. CW slows 3 pt CCW speeds the lowering time. Screw can also be used to lock 3 pt in raised position. Put the friction bolt,nut & spring on & you'll be in business.
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
15ft. Hay Rack (A65640)
15ft. Hay Rack...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
