3-Point Hitch Hydraulic problem
/ Hydraulic problem #1
rosso01
Chesapeake, a.
JD 850
I have a 1987 John Deer 850 tractor that was working fine before I changed the Hydraulic fluid. Now, the three point hitch raises up every time I start it and you have to hold the lever down to lower the hitch. Is it air trapped somewhere? How do you bleed these tractors?
Thanks
/ Hydraulic problem #2
Air will bleed by cycling 3 pt hitch up/down. Is the friction mechanism(parts keys 19-26) snug on the control handle.
/ Hydraulic problem
Thanks Jim,
I guess this is not a bleeding problem, we have been working it up and down all day. I looked and found the friction mechanism is completely missing, i can fix that. There is a knob under the seat that has open and close on it. It looks like an outdoor garden hose type. Does anyone know what this is?
Tanks for your help.
/ Hydraulic problem #4
There is a knob under the seat that has open and close on it. It looks like an outdoor garden hose type. Does anyone know what this is?.
Knob is 3 pt rate of drop screw. CW slows 3 pt CCW speeds the lowering time. Screw can also be used to lock 3 pt in raised position. Put the friction bolt,nut & spring on & you'll be in business.
Caterpillar 289D (A62180)
Caterpillar 289D...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2022 BIGHORN EXPLORER 400 EFI UTV (A62130)
2022 BIGHORN...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
CATERPILLAR 815 PADFOOT SOIL COMPACTOR (A62129)
CATERPILLAR 815...
