Hydraulic Oil Filter
/ Hydraulic Oil Filter #1
Jagmandave
Olathe, Ks
Yanmar 1602D
Has anyone ever changed one of these without draining the trans first? Can it be done or do you drown in Hydraulic oil?
I just added 2 gal after repairing a broken loader hose, so I hate to replace it again.............
/ Hydraulic Oil Filter #3
Yes, I would drain it. I think I would get new fluid but I would drain it before I messed with the filter.........Fluid is cheap compared to hydraulic repairs........
It's a spin on, looks like the original filter! 'preciate the advice!
/ Hydraulic Oil Filter #6
If this is your first time make sure you have the correct filter for it. Some look right and will even go on there correctly but if the mesh is too fine you may have problems. I tried a $10 NAPA hydraulic filter instead of the more expensive Yanmar filter and it would not work on the YM2620 that I had.
Thanks again, I had already bought a Yanmar filter from Hoye. I pretty much always use factory parts whenever they're available.
2018 John Deere 3033R (A64126)
2018 John Deere...
2022 Wildwood Forest River 170SSX (A64127)
2022 Wildwood...
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
90in. Work Bench (A65640)
90in. Work Bench...
2021 TORO TRAILER (A65643)
2021 TORO TRAILER...
AGT Industrial MX-MRT14 (A64127)
AGT Industrial...
