Hydraulic Motor Questions
/ Hydraulic Motor Questions #1
PHPaul
Platinum Member
Downeast Maine
Kubota B2650 with cab, Pasquali 986
I'm toying with the idea of building a lawn-tractor mounted string trimmer.
One thing I'm considering is powering it hydraulically.
The trimmer head I'd use came off a DR-type trimmer that had a 6hp gas engine on it.
What size motor (in either cubic inches or GPM, whichever is more appropriate) would it take to run a trimmer head?
What RPM? At a guess, I'd say the gas engine ran at about 3000 RPM and if I recall correctly the belt drive was 1:1 or very close to it. I could include a jackshaft arrangement if a speed increase was needed.
It'd be powered by the 15 horse Kawasaki engine on my LX178. Would that be adequate to run a pump large enough to provide the pressure/flow needed?
I suspect the cost of building such an animal would be prohibitive but I find the concept entertaining enough to at least do a little research.
Thanks for any help/pointers.
/ Hydraulic Motor Questions #2
Don't you have a Kubota BX? I would use the hydraulics off it, and then use the biggest motor it could run.
Nope, I have a B2650 and it's too big to get into the places I'm interested in trimming. Plus, it would tear up the lawn.
/ Hydraulic Motor Questions #4
What you need is a small hyd motor that will turn at around 1000 to 2000 rpm.
5 GPM into a .5 cu in hyd motor will have an rpm of 2310.
If you want higher rpm, increase GPM or reduce the cu in of the motor to say .3 cu in = 3850 rpm.
Something like this.
0.45 cu in PARKER MGG20020-BB1B3 HYD MOTOR
Perfect. Just what I needed to know J.J.
Thanks!
