Hydraulic issue
/ Hydraulic issue #1
Mtsoxfan
Newark Vermont
Kioti 3520SEH Holland TC29D
I own a New Holland TC29D, and was running loads of soil from field to yard. As I was scooping, I stalled the engine while scooping. Now hydraulic pump makes screaching noise when limits hit. It sounds like when its very cold out and I use the FEL. (told that was normal for NH when cold)
What steps should I take to determine the damage/repair?
/ Hydraulic issue #2
Does the loader operate correctly other than noise at lift limits?
Is noise only when you hit load limits and loader is not moving even though you wanting it to move?
If only at load limit what you are describing sounds like relief valve squealing when you hit pressure limit and nothing is hurt or damaged.
/ Hydraulic issue
Sorry, should have added more details. Yes, it operates as it should, when it should, aside from the now loud squealing/screeching. I don't want to mess it up anymore than I have.
Hydraulic fluid in normall operating range.
2000 Dodge Ram 1500 Cargo Van (A61573)
2000 Dodge Ram...
(2) UNUSED 12-16.5 TIRES ONLY (A64280)
(2) UNUSED 12-16.5...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
(2) DOUBLE AXLE FENDERS (A64280)
(2) DOUBLE AXLE...
