Hydraulic hose question
/ Hydraulic hose question #1
frontyardfarm
ware, ma
Grillo 107D, Cub Cadet
Hi,
I have a 12 ton hydraulic press that I am trying to hook up to a hydraulic motor/pump. My question is: what psi hoses do i need? The pump will supply 24,000 psi to the hydraulic jack on the press. Does this mean I need a 24,000 psi hose? Almost all the hydraulic hoses I see are no more than 10,000 psi.
The company that sells the motor wants $250 for a 6ft length of 3/8 hose assembly. Sounds crazy expensive to me which is why i am looking around to see what i can find locally, but I am lacking the understanding of what psi hose i need.
Thanks in advance for any input you might have.
/ Hydraulic hose question #2
Man, that is a heck of a pump....you sure that PSI is right ?
I don't know much about hydraulic pumps, maybe it actually runs at a lower psi but still is able to build up the pressure in the jack part of the press. The pump does have a pressure switch that has settings up to 12 ton and the press has a gauge that goes up to 12.
/ Hydraulic hose question #6
If are going to use that much psi, you need a bigger press. A 4" cyl with 2000psi well put out 25133lbs.or just a hair over the max of a 12ton press.
/ Hydraulic hose question #7
frontyardfarm,
I stock 10,000 psi Gates industrial jack hose (on a reel) in 1/4 and 3/8 id.......with factory crimp fittings
You need to check the max pressure of the pump and max rating of the cylinder, you may not need 10k hose
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
SKID STEER PLATE GRABBER (A62613)
SKID STEER PLATE...
Caterpillar 330C Excavator Service Manual (A63117)
Caterpillar 330C...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
