Hydraulic gauge
/ Hydraulic gauge #1
SylvainG
Platinum Member
South West, Qc
Kioti LK30
Hi, what's the hydraulic quick connect coupling part number on a Kioti LK30? I need to connect a hydraulic gauge to my tractor but would prefer not having to remove the coupling to thread the gauge.
Thanks
/ Hydraulic gauge
You're sure they are 1/2"? My loader and backhoe manuals mentions
DESCRIPTION SPECIFICATION PART No.
Quick Coupler 3/8" male 0001-1002
But such a generic part number is kinda meaningless.
/ Hydraulic gauge #4
I believe that your manual is correct.
I have a Kubota L48 TLB, and the quick couplers are all ISO 7241-1 B Series -3/8"
I would suspect that yours are the same.
/ Hydraulic gauge
I would presume it's written somewhere on the couplers? I guess I'll wait when I'm back at the cottage. I would prefer not buying the wrong couplers...
/ Hydraulic gauge #6
Yes......the female coupler will have some sort of code marked on it.
Best source for best price, will be Summit Hydraulics.....E-Bay.
/ Hydraulic gauge #8
---------------------- I need to connect a hydraulic gauge to my tractor but would prefer not having to remove the coupling to thread the gauge.
Thanks
The couplers are different, but this is how I did mine:
Plug it in to read max pressure:
Plug in the hose to monitor operating pressure:
/ Hydraulic gauge
This is what my quick connect on the backhoe looks like. Is that a 3/8″ ISO 7241 é„* Type? Although I do see 1/2 written on it...
Edit: Wow! That came out way bigger than I expected lol
/ Hydraulic gauge #10
SylvainG look at the couple in your picture and see if it says 8010P. I can see the 10P in the picture. If so then it is the standard 4000 series ag type connectors. ISO 5675 connectors
/ Hydraulic gauge #11
The 1/2 should be a reference to the female pipe thread of the supply end.
/ Hydraulic gauge
Thanks for the document. Looking at the picture and the chart, it does look like this one
/ Hydraulic gauge
Thanks Kenny but if I may be bold, in your first reply, you mentioned 3/8 while from what I can see, they are 1/2.
/ Hydraulic gauge
You mean this? It's almost 13/16" but more likely 20 mm
Here's a side view. It looks exactly like the 1/2:
/ Hydraulic gauge
Hi, what's that 0.081 comes from? That's roughly 5/64, which is quite small. By tip, what part do you mean? The small tip that retracts in when pushed in? I couldn't find that dimension on the link you sent.
/ Hydraulic gauge #20
.81, sorry. look at the link I posted. Same place you measured.
2012 International 4300 Reefer Truck (A63689)
2012 International...
2011 Ford Expedition SUV (A61574)
2011 Ford...
Engine (A59228)
Engine (A59228)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
2019 FREIGHTLINER M2 106 4X2 S/A 26FT  BOX TRUCK (A59912)
2019 FREIGHTLINER...
