Hydraulic gauge
/ Hydraulic gauge #1
SylvainG
Platinum Member
South West, Qc
Kioti LK30
Hi, what's the hydraulic quick connect coupling part number on a Kioti LK30? I need to connect a hydraulic gauge to my tractor but would prefer not having to remove the coupling to thread the gauge.
Thanks
/ Hydraulic gauge
You're sure they are 1/2"? My loader and backhoe manuals mentions
DESCRIPTION SPECIFICATION PART No.
Quick Coupler 3/8" male 0001-1002
But such a generic part number is kinda meaningless.
/ Hydraulic gauge #4
I believe that your manual is correct.
I have a Kubota L48 TLB, and the quick couplers are all ISO 7241-1 B Series -3/8"
I would suspect that yours are the same.
/ Hydraulic gauge
I would presume it's written somewhere on the couplers? I guess I'll wait when I'm back at the cottage. I would prefer not buying the wrong couplers...
/ Hydraulic gauge #6
Yes......the female coupler will have some sort of code marked on it.
Best source for best price, will be Summit Hydraulics.....E-Bay.
/ Hydraulic gauge #8
---------------------- I need to connect a hydraulic gauge to my tractor but would prefer not having to remove the coupling to thread the gauge.
Thanks
The couplers are different, but this is how I did mine:
Plug it in to read max pressure:
Plug in the hose to monitor operating pressure:
/ Hydraulic gauge
This is what my quick connect on the backhoe looks like. Is that a 3/8″ ISO 7241 é„* Type? Although I do see 1/2 written on it...
Edit: Wow! That came out way bigger than I expected lol
/ Hydraulic gauge #10
SylvainG look at the couple in your picture and see if it says 8010P. I can see the 10P in the picture. If so then it is the standard 4000 series ag type connectors. ISO 5675 connectors
/ Hydraulic gauge #11
The 1/2 should be a reference to the female pipe thread of the supply end.
/ Hydraulic gauge
Thanks for the document. Looking at the picture and the chart, it does look like this one
/ Hydraulic gauge
Thanks Kenny but if I may be bold, in your first reply, you mentioned 3/8 while from what I can see, they are 1/2.
/ Hydraulic gauge
You mean this? It's almost 13/16" but more likely 20 mm
Here's a side view. It looks exactly like the 1/2:
/ Hydraulic gauge
Hi, what's that 0.081 comes from? That's roughly 5/64, which is quite small. By tip, what part do you mean? The small tip that retracts in when pushed in? I couldn't find that dimension on the link you sent.
/ Hydraulic gauge #20
.81, sorry. look at the link I posted. Same place you measured.
2017 Crane Carrier Co. G-S Products 23yd Dual Side-Load Refuse Garbage Truck (A66736)
2017 Crane Carrier...
2018 GENERAC MOBILE PRODUCTS MTL6S (A67714)
2018 GENERAC...
CAT 824C GP Gear (A68134)
CAT 824C GP Gear...
2007 CATERPILLAR 277B TURBO SKID STEER (A65056)
2007 CATERPILLAR...
Unused 2023 Monroe Tufline TW92420 9ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
1997 KENWORTH T300 4X2 S/A CAB & CHASSIS TRUCK (A69167)
1997 KENWORTH T300...
