hydraulic fluid
/ hydraulic fluid #1
FishHaggis
John Deere 2320
okay dumb question here:confused:. I have had my 2320 for almost a year now and can not figure out how to check the hydraulic fluid level. None of the manuals I have for the 2320 shows me how to do this. I know this has to be pretty straight forward....... but I am asking..... because I don't know...
Thanks.
/ hydraulic fluid
Also, my FEL sticks now when I am dumping heavy loads. The loader bucket tips over to a point, then sticks for a few seconds, then continues...... I thought maybe it needs a top up on hydraulic fluid..... and that led to the question in the above post.
/ hydraulic fluid #3
all i know is that with my 4720 the trans and hydro dip stick are the same - check it and you check both. hope this helps
/ hydraulic fluid #4
Thanks.
IIRC, there's a "Oil Level Eye" in the rear a few inches high to the left of the PTO shaft.......
it should read in the middle of the eye with all cylinders retracted
/ hydraulic fluid #5
Here......at the arrow
/ hydraulic fluid #6
my old JD870 had this sticking problem your discussing. it never went away. wasnt a big deal. had nothing to do with level of fluid.
/ hydraulic fluid #7
as wdchyd pointed out, there is a sight glass near the rear PTO. I never saw any bubble in my window so I decided to add some fluid. It was almost 3 quarts low, and I feel it came this way from the dealer when I took delivery last may. I never had any issues but its good to know now that its at the proper level.
/ hydraulic fluid
thanks a bunch.......
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
Caterpillar T Series Lift Truck Service Manual (A63117)
Caterpillar T...
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2017 Ford F-250 Reading Service Truck (A61573)
2017 Ford F-250...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
