Hydraulic Filter Poll
/ Hydraulic Filter Poll #21
Highridge said:
Are the 425 and 1430's hydraulic filters the same size? I'm coming up on the 300 hour filter change and don't feel like buying 3 from PT because of the $50 minimum order.
I do believe the filters are the same on the 425 and 1430. While in Tazewell, they had mentioned the NAPA 1551 works fine. You can purchase about 6 of the NAPA filters before you would spend the the $50.00 min plus shipping.
/ Hydraulic Filter Poll #22
JJ I suspect that the recommended change interval is when the filter is used on a return line, not a suction line for a variable displacement pump. With a variable displacement pump and a filter on the suction line it is critical that the filter have as little resistance to flow as possible to avoid cavitation in the pump--which can cause expensive damage.
/ Hydraulic Filter Poll #23
I picked up a 1551 from NAPA today that I'll install tonight. It is a little smaller than the PT filter.
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A60352)
2015 SkyJack SJ86T...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
