Hydraulic Filter Poll
/ Hydraulic Filter Poll #21
Highridge said:
Are the 425 and 1430's hydraulic filters the same size? I'm coming up on the 300 hour filter change and don't feel like buying 3 from PT because of the $50 minimum order.
I do believe the filters are the same on the 425 and 1430. While in Tazewell, they had mentioned the NAPA 1551 works fine. You can purchase about 6 of the NAPA filters before you would spend the the $50.00 min plus shipping.
/ Hydraulic Filter Poll #22
JJ I suspect that the recommended change interval is when the filter is used on a return line, not a suction line for a variable displacement pump. With a variable displacement pump and a filter on the suction line it is critical that the filter have as little resistance to flow as possible to avoid cavitation in the pump--which can cause expensive damage.
/ Hydraulic Filter Poll #23
I picked up a 1551 from NAPA today that I'll install tonight. It is a little smaller than the PT filter.
