Hydraulic Diverter Valve Cartridges - DEERE - Sauer Danfoss
/ Hydraulic Diverter Valve Cartridges - DEERE - Sauer Danfoss #1
turboviking
deere 4610
Hi! This is a "Deere" LVA 12456. Trying to find one. Deere wants nearly $800. Does anyone know it there is a way to fix these?
TIA
Troy
/ Hydraulic Diverter Valve Cartridges - DEERE - Sauer Danfoss #2
What is that valve supposed to do vs what it is doing? Deere calls is some form of pressure valve.
It goes into a "diverter" valve body. That uses an electric solenoid to change from front to rear hydraulics. There are 4 of them Apparently two for bucket tilt, and two for bucket lift. Then they reverse and go to feed the top and the tilt cylinders, Oldnslo
/ Hydraulic Diverter Valve Cartridges - DEERE - Sauer Danfoss #5
Troy
By your description they sound like pilot operated directional valve. Have you tried pushing on the end of them to see if the spool moves freely similar to what kenny posted?
They are apparently directional diverters. The spool, or plunger inside is stuck in the "in" position. I tried 150 PSI of air and even a small pick tool to move it. Seems frozen in place. Thanks sir!
/ Hydraulic Diverter Valve Cartridges - DEERE - Sauer Danfoss #7
Yes these are definitely diverter spools. If you work carefully, you can get them unstuck, sometimes you have to very carefully polish the spools too if they are corroded.
Pro tip for ANY electric/hydraulic valve, diverter, whatever...Operate it frequently! Even if you have nothing connected to it, power the valve when you use the machine to keep them from sticking. Fresh clean fluid helps too, moisture in the fluid can exacerbate this problem.
/ Hydraulic Diverter Valve Cartridges - DEERE - Sauer Danfoss #8
In looking at the picture I can not tell how that valve is assembled. Does the top unscrew or is there a wire retaining ring in the nose keeping the spool from falling out? Like Kenny states careful polishing or gentle picking will generally get them working again. If polishing try not to round the edges on the spool.
So it turns out that these can be disassembled. And the spring inside was toast. Corroded in half. Fixed. Not installed yet. We will report. HUGS all. Troy
Very good Troy. any pics you can post documenting the processes of repairing would be appreciated by many!
I have them on a phone that is not near. But I will try to post. HUGS - Troy
Troy
They were stuck. The spring had corroded, probably due to moisture in the HYD fluid.
/ Hydraulic Diverter Valve Cartridges - DEERE - Sauer Danfoss #14
Troy
Thanks for posting the pictures of those valves. Were the spools also corroded?
Hi, the spools were hard anodized and in good shape. They were in bad need of cleaning. I just buffed them with scotchbrite pad lightly.
/ Hydraulic Diverter Valve Cartridges - DEERE - Sauer Danfoss #16
They are apparently directional diverters. The spool, or plunger inside is stuck in the "in" position. I tried 150 PSI of air and even a small pick tool to move it. techzpod download mobdro
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2004 JOHN DEERE 310G BACKHOE (A60429)
2004 JOHN DEERE...
2023 Ford Expedition SUV (A59231)
2023 Ford...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
MAHINDRA 3650P TRACTOR (A60430)
MAHINDRA 3650P...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2021 FREIGHTLINER...
