Hydralic issues
/ Hydralic issues #1
blane
Type 830 code 830a serial number 145317 L
Hello I'm new to the site.
I'm having hydralic issues on my john deere 830 German made. The loader will function up/down and bucket will tilt but it seems to struggle to lift a load. It acts like it is bypassing back to the tank and the rear 3 pt stalls with nothing attached to it. Not sure if any adjustments could be made to the relieve valve.not sure how this system works.any help would be appreciated.
Thanks
/ Hydralic issues #2
Welcome to TBN
Best I can suggest is to get a pressure gage fixed up with quick couplers to plug into your hyd. system at different points. Then track down the pressures to find (hopefully) the problem. Seems you need to know where you have pressure, how much, and where you don't have it.
/ Hydralic issues #3
Welcome to this forum
Be aware JD 830 utility tractor has open center hyd system. How many hrs of use since hyd filter was changed & hyd oil suction screen checked/cleaned? I suggest to check hyd system pressure which should be around 2000 psi.
/ Hydralic issues
Thankyou for the information I wll check.
