Hydo Question
/ Hydo Question #1
langlom1
JD 4600
#1. Runs faster in reverse than in forward. Getting worse?
#2. Have a pump whine, step on pedals fwd or rev will stop whine?
I have a 4600 compact tractor,
/ Hydo Question #2
Suggest moving this from the AG tractor section
/ Hydo Question #3
It would really help if you could express yourself better.
/ Hydo Question #4
Sounds like you have a pressure relief valve that is opening when you are stopped. that would indicate too much pressure on one side or the other. There should an open center valve that would allow the pump to dump back to the tank. Try checking your hoses to make sure they not swelled or crimped or blocked ( I've seen hoses that come apart on the inside and block fluid flow.
/ Hydo Question
Thanks, I will check it out.:thumbsup:
Milt
2022 EZ-GO ELITE...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2011 Polaris RZR 900  (A62679)
2011 Polaris RZR...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
ALLMAND NIGHT-PRO LIGHT STAND (A65643)
ALLMAND NIGHT-PRO...
