Hydo Question
/ Hydo Question #1
langlom1
JD 4600
#1. Runs faster in reverse than in forward. Getting worse?
#2. Have a pump whine, step on pedals fwd or rev will stop whine?
I have a 4600 compact tractor,
/ Hydo Question #2
Suggest moving this from the AG tractor section
/ Hydo Question #3
It would really help if you could express yourself better.
/ Hydo Question #4
Sounds like you have a pressure relief valve that is opening when you are stopped. that would indicate too much pressure on one side or the other. There should an open center valve that would allow the pump to dump back to the tank. Try checking your hoses to make sure they not swelled or crimped or blocked ( I've seen hoses that come apart on the inside and block fluid flow.
/ Hydo Question
Thanks, I will check it out.:thumbsup:
Milt
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2013 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2013 ALLMAND...
CATERPILLAR 324EL LONG REACH EXCAVATOR (A65053)
CATERPILLAR 324EL...
2012 GMC SAVANA VAN (A67714)
2012 GMC SAVANA...
AM GENERAL M1123 HMMWV 2 DOOR TRUCK BODY (INOPERABLE) (A67714)
AM GENERAL M1123...
2012 GORILLA BUILT MANIFOLD TRAILER (A67714)
2012 GORILLA BUILT...
