Mechanos
Now that cold temps are here, I see a lot of discussions about block heaters, oil pan heaters, etc., etc. So, is anyone here using a transmission/hydraulic oil heater? I see that one is an available option on many models.
I suppose a heater cannot hurt, but where are you located that you think you might need an oil heater?
I'm in the midwest, and don't really think that I need a hyd. oil heater... I was just curious how many people out there used them. Everyone is so concerned about starting their engines with cold oil, but nobody seems to be concerned about immediately pumping cold hydro oil through the trans, etc.
I've been told that after starting the engine and letting idle for a few minutes, I can close the rate-of-drop valve and move the TPH lever into a raised position to put the hyd. system into bypass and let it run for a few minutes that way to help warm the hydro oil. But I'm not totally convinced that is a good idea.
Well, that sounds exactly like what I was told I could do. On my JD 955, if I completely close the rate of drop valve and then move the TPH lever to any raised position, the hydraulic system is dead-headed and goes into relief. Sounds like the same thing as holding the FEL controls hard over after the cylinders have reached the end of their stroke..... only you don't have to hold it there. But you do have to remember that you did and not walk off an leave it operating in that state. Manually holding the FEL control would provide a bit of a built-in fail-safe.
RADIUM said:One simple suggestion and I tell everyone this synthetic synthetic synthetic transmission fluid and engine oil I don't care how cold it gets within reason of course it runs like water try a test for yourself put a bottle of synthetic outside and some standard transmission oil and watch the difference of flow characteristics simple enough, I know it costs more money how much is your tractor worth? I constantly hear people tell me they're having starting trouble, my tractor lives outside under the big blue sky sits for weeks at a time kicks right over when ever I need her, probably maintain fuel, 0-40W engine oil , and synthetic transmission fluid for cold climates. It's really kind of amazing to realize how may times dealers don't explain this to their customers or properly prepare the tractors for the environments they're heading towards just makes you wonder who selling this equipment take care
