Hyd lines overheating
/ Hyd lines overheating #1
sugargrovefarmer
Sugar Grove
Farmall Super M
Hi Guys! I have a external hyd pump that mounts off the dist mount on my super m My fluid seems to get extremly hot how do I check to see if the hose routing is correct, The line from the pump goes to the inlet side of the control valve and the outlet goes back to the resivior tank
/ Hyd lines overheating #2
If your valve has some debris in it blocking the port then the fluid may be running in relief, this would cause heat buildup. Maybe buy one of those infrared thermometers to check exactly what the temp is.
/ Hyd lines overheating #3
yeah or perhaps excessive internal leakage
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
5ft. Wooden Cowboy Statue (A61574)
5ft. Wooden Cowboy...
5/16" CHAIN, SNAP BINDER (A64276)
5/16" CHAIN, SNAP...
