Hyd lines overheating
/ Hyd lines overheating #1
sugargrovefarmer
Sugar Grove
Farmall Super M
Hi Guys! I have a external hyd pump that mounts off the dist mount on my super m My fluid seems to get extremly hot how do I check to see if the hose routing is correct, The line from the pump goes to the inlet side of the control valve and the outlet goes back to the resivior tank
/ Hyd lines overheating #2
If your valve has some debris in it blocking the port then the fluid may be running in relief, this would cause heat buildup. Maybe buy one of those infrared thermometers to check exactly what the temp is.
/ Hyd lines overheating #3
yeah or perhaps excessive internal leakage
(2) Denman Tires w/Rims (A64127)
(2) Denman Tires...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
FORD F750 BUCKET TRUCK (A65054)
FORD F750 BUCKET...
Takeuchi TL6R (A64126)
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
(2) FORESTRY RIMS (A64276)
(2) FORESTRY RIMS...
