Hyd lines overheating
/ Hyd lines overheating #1
sugargrovefarmer
Sugar Grove
Farmall Super M
Hi Guys! I have a external hyd pump that mounts off the dist mount on my super m My fluid seems to get extremly hot how do I check to see if the hose routing is correct, The line from the pump goes to the inlet side of the control valve and the outlet goes back to the resivior tank
/ Hyd lines overheating #2
If your valve has some debris in it blocking the port then the fluid may be running in relief, this would cause heat buildup. Maybe buy one of those infrared thermometers to check exactly what the temp is.
/ Hyd lines overheating #3
yeah or perhaps excessive internal leakage
AGI Westfield WRX 8-61 (A64126)
AGI Westfield WRX...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
2019 DODGE RAM 1500 (A65643)
2019 DODGE RAM...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
