hyd. cyl. mfg. and attachment plate dimesions
   / hyd. cyl. mfg. and attachment plate dimesions #21
next pic
   / hyd. cyl. mfg. and attachment plate dimesions #22
pic 3
   / hyd. cyl. mfg. and attachment plate dimesions #23
pic 4
   / hyd. cyl. mfg. and attachment plate dimesions #24
I built 2 of these this weekend. They are made from all 1/4" metal with the exception of the 5/8 bar for the top hook up. The plate is 12" by 19" it could be trimmed but I felt I would weight till its application. Notice the braces at the bottom for added strength of the bottom hookups.
   / hyd. cyl. mfg. and attachment plate dimesions #25
Do you like your setup better than PT's adapter plate. I am trying to make an adapter plate for my older three point machine. but will have to use 5/8 in for my 1445. I just bought one of those motorized oxy-acetylene torch/machine that runs along a track. They say, that it will cut up to 4 in steel, and if a plasms torch is installed. it will cut all the light stuff to 3/4 in. The plasma will cut any kind of metal.
   / hyd. cyl. mfg. and attachment plate dimesions #26
<font color="red">motorized oxy-acetylene torch/machine </font>
Sounds neat
Picture?
URL?
/forums/images/graemlins/smile.gif
   / hyd. cyl. mfg. and attachment plate dimesions #27
This is a similar unit.
   / hyd. cyl. mfg. and attachment plate dimesions #28
J.J. I don’t think my adapter plate is better. The added structure at the bottom is because I had ¼” plate and wanted to use it. I believe with that structure it will be comparable in strength with PT’s 3/8 adaptor plate. The extra 12 by 19 plate can be trimmed if needed when installed on what ever attachment it is to be used on.
That sure sounds like a nice piece of equipment you bought. We have a Plasma cutter at work and like you say as well as carbon it really comes in handy on stainless steel. I am really interested on how you come out on changing you hook up to the quick attach. Send us some pics when you’re ready.
   / hyd. cyl. mfg. and attachment plate dimesions #29
Making a few more quick plates. Here is a pic of the tops.
   / hyd. cyl. mfg. and attachment plate dimesions #30
And look if you make 4 of them it kinda makes a square.
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
UNUSED FUTURE SG45 45" HYD STUMP GRINDER (A57193)
UNUSED FUTURE SG45...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
UNUSED PABREAK BE232 HYD BACKHOE DIGGER ARM (A57193)
UNUSED PABREAK...
