Hyd adjustments
/ Hyd adjustments #1
big early
cannon falls
S650 bobcat
I have a 2013 S650 bobcat. Problem is when using the foot controls the hyd are slow how do i adjust this, we have skidsteers at work and the speed of the hyds is way faster then mine any ideas? Thanks
/ Hyd adjustments #2
:welcome:
To the TBN forum Early. We are glad that you joined.
I can't help but someone will be along shortly that will.
/ Hyd adjustments #3
:welcome: Welcome to the forum!
I'm going to move this thread over to our Bobcat section to see if we can get you some answers.
/ Hyd adjustments #4
If your SSL is ACS or SJC try calibrating the actuators . :thumbsup:
/ Hyd adjustments #5
Other possible causes.
Pedals not moving to full stroke - check/clean debris out of foot pedal area.
Gear pump not spinning fast enough due to;
belt slippage - adjust or replace belt.
engine not at full RPM - If Kubota engine, throttle adjustment or stretched cable
If Doosan/Bobcat engine faulty throttle position switch.
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63118)
2011 Peterbilt 6x4...
(2) ALUMINUM TRUCK TOOL BOXES & MISC (A63745)
(2) ALUMINUM TRUCK...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59910)
2021 KENWORTH T680...
FARMALL SUPER A HI-CROP TRACTOR (A63745)
FARMALL SUPER A...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
1984 John Deere 750 Utility Tractor (A63116)
1984 John Deere...
