Hyd adjustments
/ Hyd adjustments #1
big early
cannon falls
S650 bobcat
I have a 2013 S650 bobcat. Problem is when using the foot controls the hyd are slow how do i adjust this, we have skidsteers at work and the speed of the hyds is way faster then mine any ideas? Thanks
/ Hyd adjustments #2
:welcome:
To the TBN forum Early. We are glad that you joined.
I can't help but someone will be along shortly that will.
/ Hyd adjustments #3
:welcome: Welcome to the forum!
I'm going to move this thread over to our Bobcat section to see if we can get you some answers.
/ Hyd adjustments #4
If your SSL is ACS or SJC try calibrating the actuators . :thumbsup:
/ Hyd adjustments #5
Other possible causes.
Pedals not moving to full stroke - check/clean debris out of foot pedal area.
Gear pump not spinning fast enough due to;
belt slippage - adjust or replace belt.
engine not at full RPM - If Kubota engine, throttle adjustment or stretched cable
If Doosan/Bobcat engine faulty throttle position switch.
