Hyd adjustments
/ Hyd adjustments #1
big early
cannon falls
S650 bobcat
I have a 2013 S650 bobcat. Problem is when using the foot controls the hyd are slow how do i adjust this, we have skidsteers at work and the speed of the hyds is way faster then mine any ideas? Thanks
/ Hyd adjustments #2
:welcome:
To the TBN forum Early. We are glad that you joined.
I can't help but someone will be along shortly that will.
/ Hyd adjustments #3
:welcome: Welcome to the forum!
I'm going to move this thread over to our Bobcat section to see if we can get you some answers.
/ Hyd adjustments #4
If your SSL is ACS or SJC try calibrating the actuators . :thumbsup:
/ Hyd adjustments #5
Other possible causes.
Pedals not moving to full stroke - check/clean debris out of foot pedal area.
Gear pump not spinning fast enough due to;
belt slippage - adjust or replace belt.
engine not at full RPM - If Kubota engine, throttle adjustment or stretched cable
If Doosan/Bobcat engine faulty throttle position switch.
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2012 WESTERN STAR  4900 SB (A63569)
2012 WESTERN STAR...
Rogator RG1100 (A63118)
Rogator RG1100...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63118)
2023 Kubota...
Cat 3-4 quick hitch (A64047)
Cat 3-4 quick...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
