Hudson Trailers?
/ Hudson Trailers? #1
Harleazy
Charlotte
John deer
Hi I'm new to forum and very interested in purchasing a Hudson bros Trailer, Looking for feed back on them from several members if possible anyone deal with them any pros and cons ?
Thank you
/ Hudson Trailers? #2
I've had one for almost 10 years not a single issue IMO they are a quality made product.
/ Hudson Trailers? #4
I bought a used one when I bought my B7610 in 2009, an '07 18' Hudson HSE Deluxe trailer - 5 Ton.
attachment.php
Fit just fine for years, mostly unused form 2009 to 2012.
Little bit tight now
attachment.php
Doubles as enclosed with a little work
attachment.php
/ Hudson Trailers? #5
I had an 18' Hudson with hydraulic tilt bed for several years 2003-2007. It was a good unit. If they are still made to the same quality it should be a good trailer. The only issue I ever had was the fuse would blow on the lift battery charging line (from the truck's 7 pin connector). The tilt would slow down as the battery got weaker. That was a common known issue with those trailers. Just had to replace that fuse now and then.
/ Hudson Trailers?
Thanks for the reply's anyone else have any feed back on these
/ Hudson Trailers? #7
I have had two hudson trailers in the last 8 years. The first was a 5 ton metal deck tilt bed. I traded to a 6 ton tilt bed becasue the tail of the trailer was too low to the ground and rubbed on everything. My father bought a 5 ton with ramps and it has worked out great for him. I wish I had gotten a deck over since I haul pallets and other material which is loaded and unloaded with a forklight. I upgraded to a larger excavator and need to move up to a gooseneck trailer. My dealer did not have a Hudson in stock and said it would be 8-10 weeks before they would see one.
I would recommend them without hesitation.
Good luck,
Mike
/ Hudson Trailers? #8
Hudson is a quality manufacturer. They typically rate their trailers as 5 ton, 4 ton, 3 ton, etc...Those ratings are what they will haul. The GVWR is higher. They will price out comparable to a PJ or other higher end manufacturer. Difficult to find a used unit at a decent price.
/ Hudson Trailers?
Well I placed an order through local dealer for a Hudson I'll be picking it up at the manufacturer soon I'll post pictures soon
/ Hudson Trailers? #10
I sold my 7T Hudson goose several months ago. I bought my new goose from Mike Moore Welding which is down the road from Hudson. He used to work for them. A lot happier with his work.
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2022 EZ-GO ELITE...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
BUSH HOG 4R48" ROLLING CULTIVATOR (A64278)
BUSH HOG 4R48"...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
